3 Way Globe Valves Purpose
Three Way Globe control valves are used to combine two flows or to divert one flow into two outlets.
They are designed to replace and perform the functions of two single ported control valves acting in opposite directions, in con- verging or diverging the flow.
They can be used to control the circulation of water, oil, sea water or other liquids, in heating or cooling applications involving heat exchange bypass control.
They can also be used in blending systems and on-off selector systems.
