A ___ -actuated solenoid coil is symbolized with a circle with short wire leads extended on either side along the horizontal centerline of the circle, whereas a ___ -actuated solenoid coil is symbolized with a zigzag line
A ___________ -actuated solenoid coil is symbolized with a circle with short wire leads extended on either side along the horizontal centerline of the circle, whereas a ___________ -actuated solenoid coil is symbolized with a zigzag line laid on its side with short wire leads extended on either side along the horizontal centerline of the two saw tooth arches.
A) voltage; voltage
B) voltage; current
C) current; current
D) current; voltage
Show Answer
Answer:B
