A phenomenon referred to as “___________ error” occurs when reading the pointer against the selected scale on an analog meter:
If you read the scale from a side-angle view, a measured value of 115 volts may appear as 112 volts or 118 volts according to which side of the pointer you are viewing from.
The 115-volt reading only occurs when you are looking straight on at the pointer suspended over the scale.
A) parallax
B) paradox
C) periodontal
D) parallel
Show Answer
Answer:A
