A pump induction motor is switched on to a supply 25 percent lower than its rated voltage.
The pump runs eventually
A. the pump will get heated and consequently get damaged
B. the pump will stall after sometimes
C. the pump will continue to run at lower speed without damage
D. none of these answers
Show Answer
Answer: A
