About Din Rail fiber optic patch panel
Nano DIN Rail fiber optic patch panel is designed to support fusion splicing or direct termination of the fibers. Because of its compact and ruggedly designed case, it is suitable for industrial applications. The device includes a splice tray for fusion splicing. It is suitable for mounting in DIN Rail panels where there are space constraints inside PLC’s and also suitable for CCTV & surveillance applications.
Din rail fiber optic patch panel is compact in size and can be mounted in a cabinet with other din rail equipment. Din Rail mount enclosures are suitable to mount in substation automation networks. Din rail mount fiber patch panel is used to provide a maximum number of fiber connections in a minimal footprint.
DIN Rail Fiber optic patch panel is used in CCTV traffic monitoring, toll systems, and environmental monitoring equipment where these can be secured in small wayside cabinet backplane or side panel. The patch panel can be loaded with a variety of adapters like ST, SC, FC, and LC.
DIN Rail Fiber Optic Enclosure provides enclosed fiber protection for terminated distribution style cabling and includes a PG 11 or PG 13.5 cable gland to secure fiber cable(s) exiting the enclosure. The new Nano Patch panel is a termination panel for cables that need to be connected to active equipment such as switches or fiber to Ethernet converters. The Unisol DIN Rail fiber optic patch panel is ideal for use in a wide range of industrial applications. The industrial design makes it highly suited for use in Machine Building, Transportation, Alternative Power Generation, Power Transmission & Distribution, and Oil & Gas markets, as well as more general use in the enterprise, buildings and other applications. Unisol developed the Nano series DIN rail mountable enclosures. This economical series of enclosures is the perfect choice for terminating fiber data cables where the expense of an outdoor enclosure in not desired.
These frames can mount either to standard 35mm DIN rail or directly to a wall for convenient installation in any location. These boxes are perfect for transitioning outdoor rated to indoor rated cables without the need to install an entire rack enclosure or panel system. we are confident that the fiber optic patch panel you choose will provide reliable service for years. Available in an attractive Black or RAL 7035 powder coat finish.
