Simultaneously we have heard that Ultrasonic waves being used for level, flow, detection, but no it can be also used for temperature detection.
Principle of operation is very simple acoustic waves travels at different speeds at different temperatures.
Velocity of acoustic wave is high when temperature is low, and vice-verse.
Acoustic waves are passed through solids, and based on transit time we are able to determine temperature.
Temperature of various gases can be determined by triggering pulse and determining transit time.
Rhenium sensors provide better output in hostile environment.
They can measure temperature up to plasma level(20,000 C).
The acoustic pulses are generated by piezoelectric crystal, which resonate at frequency range of about 3Mhz.
Temperature and velocity exhibits relationship derived by the formula:
c is velocity of sound.
R is gas constant per mole.
k is Boltzmann constant.
m is mass of single molecule.
T is absolute temperature.
Advantage:
High accuracy
No leakage
Used where medium is at very high temperature.
Disadvantage:
High cost.
No ideal gas behaviour.
The device posses drift in parameters.
Applications:
- Furnace & Nuclear reactors.
