Additel ADT 914A Pressure Test Hand Pump
-14 to 375 psi, portable pneumatic air pressure pump
OVERVIEW
The ADT 914A Pneumatic Pressure Test Pump is a hand operated pressure pump designed to generate pressure from -14psi (-0.95bar) to 375psi (25bar). A high-quality screw press is designed for fine pressure adjustment, with an adjustment resolution up to10 Pa (0.1 mbar). A specially designed shut-off valve makes the pressure as stable as possible during calibration. A built-in gas-liquid isolator protects the pump from moisture and dirt to reduce the need for maintenance. Two hand-tight connectors installed on the pump allow easy connecting and disconnecting to the test pump without the need for PTFE tape or wrenches. The ADT 914A is an ideal comparison test pump for pressure instruments calibration
GENERAL FEATURES
• Portable
Only 3.3 lb
• High Resolution
10 Pa (0.1 mbar)
High-quality screw press for fine pressure adjustment
• Great Stability
• Durable and Minimal Maintenance
Built-in gas-liquid isolator protects the pump from moisture and dirt
• Easy-to-use
• Hand-tight Connectors
Allows easy connecting and disconnecting to the test pump without the need for PTFE tape or wrenches
APPLICATIONS
The ADT 914A Pneumatic Pressure Test Pump is designed to generate pressure from 95% vacuum to 375 psi (25 bar) for the application requiring accurate pressure testing and calibration. It can be used in calibrating pressure gauges, transmitters, or other pressure measuring instruments.
SPECIFICATIONS
• Media: Air.
• Generated Pressure Range:
14 psi (0.95 bar) vacuum to 375 psi (25 bar) positive pressure
• Pressure Resolution:
10 Pa (0.1 mbar).
• Material:
Ram/adapters: SST
Body: SST/aluminum
Seals: Buna-N
• Connection:
Hand-tight connectors for both test gauge and reference gauge.
Test Gauge Connection: 1/4" NPT female.
Reference Gauge Connection: 1/4" NPT female.
• Dimensions:
Height: 5.12’’ (130 mm)
Base: 9.45’’ (240 mm) x 4.72’’ (120 mm)
• Weight:
3.31 lb (1.5 kg).
914A datasheet.pdf (83.9 KB)
