List the Advantages and Disadvantages of a Magnetic Flow Meter used in industrial flow measurement.
A magnetic flow meter provides an unobstructed flow path, so it causes a negligible pressure drop due to its pipe flow measurement function.
The magnetic flow meter has a typical turndown ratio of 40:1, which means it can accurately measure a flow rate of as little as 1/40th of its maximum reading. This is higher than the turndown ratio for any of the other commonly used types of pipe flow meter.
The typical accuracy for a magnetic flow meter is + 0.5 % of full scale. This is among the best of the various pipe flow meters.
The effect of fluid viscosity on flow through a magnetic flow meter is essentially the same as for flow through the pipe itself.
The magnetic flow meter can be used for pipe flow measurement of either clean or dirty liquids, including wastewater, corrosive liquids, or slurries.
The cost of a magnetic flow meter is relatively high compared to other types of pipe flow meter.
The magnetic flow meter is used primarily for liquids. It doesn’t work well for measurement of gas flow rate.
In order to use a magnetic flow meter for measurement of a liquid’s flow rate, that liquid must be conductive. Hence it can’t be used for non-conductive fluids as mentioned above.
