Advantages and Disadvantages of NPT Fittings
NPT connections seal pipes for fluid and gas transfer. They’re available in iron and brass for low-pressure applications and carbon and stainless steel for higher pressure. The nominal pipe size can be identified by physically measuring the thread diameter, then subtracting 1/4″. NPT (or National Pipe Taper) is a U.S. standard for tapered threads widely used on pipes and fittings for over 100 years.
NPT connections rely on thread deformation- a metal to metal sealing design where the threads of the connectors themselves form together. This design is ideal fore single assembly applications and not recommended where connections will be assembled and disassembled frequently due to wear on the threads from deformation.
NPT Fittings
NPT%20Fittings
Disadvantages of NPT Fittings:
Sealing performance decreases rapidly with re-assembly and larger sizes are more prone to leaking because of the leak path size
  • Can be prone to port expansion or cracking from over tightening
  • Can make it more difficult to properly orient shaped connectors
  • Thread lubricant required can cause system contamination
  • Are not suitable for the highest pressures
Advantages of NPT Fittings:
  • Are readily available
  • Come in a large variety of sizes, shapes, combinations and materials
  • Widely used and well known
  • Offer simple assembly without flaring of tubes, using sleeves, or introducing seals or o-rings
NPTF and NPSM Thread Styles
Two of the most common variations of this pipe thread standard are NPTF and NPSM thread styles.
Where traditional NPT threads have a small clearance between the crest and root of the mating threads requiring the use of sealant, the NPTF thread root does not allow this clearance. It contacts and deforms the mating thread crest. NPTF, or National Pipe Taper Fuel, style connections are widely used in fluid power systems. This type of connector is designed to provide a dry thread seal. However, lubricant is often still used to ease assembly.
NPSM, or National Pipe Straight Mechanical threads, are also often found in fluid power systems. The female component incorporates a straight, non-tapered thread with an inverted 30° chamfer of the male connector on the seat of the female. This is a mechanical seal. If and NPTF male is properly chamfered it will also seat with NPSM female connection. They are especially suited for manufacturers and end users that rely on versatility.
NPT style threads are very similar to BSP, certain DIN styles, and other non-US thread styles. Although visually very similar, the differences in thread dimensions, pitch and angle make them incompatible, so care needs to be taken to properly identify your connection to create a safe and leak resistant seal.
source
NPT (National Pipe Thread) fittings are commonly used in various industries, particularly in piping systems in the United States and Canada. They have tapered threads that create a seal when tightened.
Here are some of their advantages and disadvantages:
  1. Sealing Mechanism: The taper of NPT threads allows for a tight and effective seal, as the threads deform and press together under tension, creating a mechanical seal in addition to any thread sealant used.
  2. Ease of Assembly: NPT fittings are fairly easy to assemble. The fittings do not need to be oriented in any particular direction, which makes them versatile for various applications.
  3. Availability: NPT fittings are widely available and commonly used in North America, making replacements and new installations easy to source.
  4. Durability: They are typically very durable, especially when made from robust materials such as stainless steel.
  1. Potential for Leakage: Although the taper of NPT threads can provide a good seal, it also creates a potential for leakage if not properly installed or if subjected to excessive vibration or thermal cycling. Thread sealant is usually required to ensure a leak-proof seal.
  2. Limited Reusability: Due to the nature of the sealing mechanism (the threads deforming under tension), repeated use can wear out the threads and reduce their ability to form a seal.
  3. Installation Care: NPT fittings need to be carefully installed. Over-tightening can split the female fitting, while under-tightening can lead to leaks.
  4. Pressure Drop: The threads can potentially cause turbulence in the fluid flow, which might cause a small pressure drop.
The suitability of NPT fittings will depend on the specifics of your application, including factors like the required pressure rating, the nature of the fluid being transported, the need for disassembly and reassembly, and other factors.
Other types of fittings, such as BSPP (British Standard Pipe Parallel), may be more suitable for some applications, particularly those that require a better seal or more frequent disassembly and reassembly.
