AGA & API Standard using for Fiscal metering measurement
API Standards using for Fiscal Metering measurement
API 14H 2007
Specification for Wellhead Surface Safety Valves and Underwater Safety Valves for Offshore Service
API 600 2009
Bolted Bonnet Steel Gate Valves for Petroleum and Natural Gas Industries - Modified National Adoption
API 6AV1
Specification for Verification Test of Wellhead Surface Safety Valves and Underwater Safety Valves for Offshore Service
API 6AV2
Installation, Maintenance, and Repair of Surface Safety Valves and Underwater Safety Valves Offshore
API MPMS CH.10.1 2007
Standard Test Method for Sediment in Crude Oils and Fuel Oils by the Extraction Method
API MPMS CH.10.2 2007
Determination of Water in Crude Oil by Distillation
API MPMS CH.10.3 2008
Standard Test Method for Sediment and Water in Crude Oil by the Centrifugal Method (Laboratory Procedure)
API MPMS CH.10.4 1999
Determination of Water and/or Sediment in Crude Oil by the Centrifuge Method (Field Procedure)
API MPMS CH.10.5 2005
Standard Test Method for Water in Petroleum Products and Bituminous Materials by Distillation
API MPMS CH.10.6 2004
Standard Test Method for Water and Sediment in Fuel Oils by the Centrifuge Method (Laboratory Procedure)
API MPMS CH.10.7 2002
Standard Test Method for Water in Crude Oils by Potentiometric Karl Fischer Titration
API MPMS CH.10.8 2005
Standard Test Method for Sediment in Crude Oil by Membrane Filtration
API MPMS CH.10.9 2002
Standard Test Method for Water in Crude Oils by Coulometric Karl Fischer Titration
API MPMS CH.11
Add-in Program for Microsoft Excel
API MPMS CH.11.1
Dynamic Link Library & Source Code
API MPMS CH.11.2
Data File of Chapters 11.2.2 and 11.2.2M
API MPMS CH.11.2.2
Compressibility Factors for Hydrocarbons 0.350~0.637
API MPMS CH.11.2.2 1986
Compressibility Factors for Hydrocarbons 350~637
API MPMS CH.11.2.2M 1987
Compressibility Factors for Hydrocarbons; 0.350-0.637 Relative Density (60°F/60°F) and -50°F to 140°F Metering Temperature
API MPMS CH.11.2.4 2007
Compressibility Factors for Hydrocarbons; 350-637 Kilograms per Cubic Meter Density (15°C) and -46°C to 60°C Metering Temperature
Temperature Correction for the Volumes of NGL and LPG Tables 23E, 24E, 53E, 54E, 59E, 60E
API MPMS CH.11.2.5 2008
A Simplified Vapour Pressure Correlation for Commercial NGLs
API MPMS CH.11.3.2.1 2008
Ethanol Density and Volume Correction Factors
API MPMS CH.11.3.3
Ethylene Density
API MPMS CH.11.3.3.2 2007
Propylene Compressibility
API MPMS CH.11.4.1 2003
Properties of Reference Materials: Part 1 - Density of Water and Water Volume Correction Factors for Calibration of Volumetric Provers
API MPMS CH.11.5 2009
Density/Weight/Volume Intra-conversion: Part 1 - Conversions of API Gravity at 60°F Part 2 - Conversions for Relative Density (60/60°F) Part 3 - Conversions for Absolute Density at 15°C
API MPMS CH.12.1.1
Calculation of Static Petroleum Quantities, Part 1, Upright Cylindrical Tanks and Marine Vessels
API MPMS CH.12.1.2
Calculation of Static Petroleum Quantities, Part 2, Calculation Procedures for Tank Cars
API MPMS CH.12.2.1 1995
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volume Correction Factors - Part 1 - Introduction
API MPMS CH.12.2.2 2003
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volume Correction Factors - Part 2 - Measurement Tickets
API MPMS CH.12.2.3 1998
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volumetric Correction Factors, Part 3—Proving Reports
API MPMS CH.12.2.4 1997
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volumetric Correction Factors, Part 4—Calculation of Base Prover Volumes by Water draw Method
API MPMS CH.12.2.5 2001
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volumetric Correction Factors, Part 5—Base Prover Volume Using Master Meter Method
API MPMS CH.12.3 2007
Calculation of Volumetric Shrinkage from Blending Light Hydrocarbons with Crude Oil
API MPMS CH.13.1 1985
Statistical Concepts and Procedures in Measurement
API MPMS CH.13.2 1994
Statistical Methods of Evaluating Meter Proving Data
API MPMS CH.14.1 2006
Collecting and Handling of Natural Gas Samples for Custody Transfer
API MPMS CH.14.10 2007
Measurement of Flow to Flares
API MPMS CH.14.2 1994
Compressibility Factors of Natural Gas and Other Related Hydrocarbon Gases
API MPMS CH.14.3.1 1990
Concentric, Square-Edged Orifice Meters, Part 1 General Equations and Uncertainty Guidelines
API MPMS CH.14.3.2 2000
Concentric, Square-Edged Orifice Meters, Part 2 Specification and Installation Requirements
API MPMS CH.14.3.3 1992
Concentric, Square-Edged Orifice Meters, Part 3 Natural Gas Applications
API MPMS CH.14.3.4 1992
Concentric, Square-Edged Orifice Meters, Part 4 Background, Development, Implementation Procedures and Subroutine Documentation
API MPMS CH.14.4 1991
Converting Mass of Natural Gas Liquids and Vapours to Equivalent Liquid Volumes
API MPMS CH.14.5 2009
Calculation of Gross Heating Value, Relative Density, Compressibility and Theoretical Hydrocarbon Liquid Content for Natural Gas Mixtures for Custody Transfer
API MPMS CH.14.6 1991
Continuous Density Measurement
API MPMS CH.14.7 2009
Mass Measurement of Natural Gas Liquids
API MPMS CH.14.8 1997
Liquefied Petroleum Gas Measurement
API MPMS CH.14.9 2003
Measurement of Natural Gas by Coriolis Meter
API MPMS CH.15 2001
Guidelines for Use of the International System of Units (SI) in the Petroleum and Allied Industries
API MPMS CH.16.2 1994
Mass Measurement of Liquid Hydrocarbons in Vertical Cylindrical Storage Tanks by Hydrostatic Tank Gauging
API MPMS CH.17.1 2008
Guidelines for Marine Cargo Inspection
API MPMS CH.17.10.2 2007
Measurement of Refrigerated and/or Pressurized Cargoes on Board Marine Gas Carriers, Part 2 Liquefied Petroleum and Chemical Gases
API MPMS CH.17.11 2009
Measurement and Sampling of Cargoes On Board Tank Vessels Using Closed/Restricted Equipment
API MPMS CH.17.12 2008
Procedure for Bulk Liquid Chemical Cargo Inspection by Cargo Inspectors
API MPMS CH.17.2 1999
Measurement of Cargoes on Board Tank Vessels
API MPMS CH.17.3 1992
Guidelines for Identification of the Source of Free Waters Associated with Marine Petroleum Cargo Movements
API MPMS CH.17.4 1994
Method for Quantification of Small Volumes on Marine Vessels (OBQ/ROB)
API MPMS CH.17.5 2003
Guidelines for Cargo Analysis and Reconciliation
API MPMS CH.17.6 1994
Guidelines for Determining Fullness of Pipelines Between Vessels and Shore Tanks
API MPMS CH.17.7 1995
Recommended Practices for Developing Barge Control Factors (Volume Ratio)
API MPMS CH.17.8 1998
Guidelines for Pre-Loading Inspection of Marine Vessel Cargo Tanks
API MPMS CH.17.9 2012
Vessel Experience Factor (VEF)
API MPMS CH.18.1 1997
Measurement Procedures for Crude Oil Gathered from Small Tanks by Truck
API MPMS CH.19 1962-2008
Evaporation Loss Measurement - Storage Tanks (various parts)
API MPMS CH.2.2 1986
Temperature and Pressure Volume Correction Factors for Generalized Crude Oils, Refined Products and Lubricating Oils
API MPMS CH.2.2A 1995
Measurement and Calibration of Upright Cylindrical Tanks by the Manual Strapping Method
API MPMS CH.2.2B 1989
Calibration of Upright Cylindrical Tanks Using the Optical Reference Line Method
API MPMS CH.2.2C 1993
Calibration of Upright Cylindrical Tanks Using the Internal Optical Triangulation Method
API MPMS CH.2.2D 1995
Calibration of Upright Cylindrical Tanks Using the Internal Optical Ranging Method
API MPMS CH.2.2E 2002
Calibration of Upright Cylindrical Tanks Manual Method
API MPMS CH.2.2F 2002
Calibration of Upright Cylindrical Tanks Internal Electro-Optical Distance-Ranging Method
API MPMS CH.2.7 1991
Manual of Petroleum Measurement Standards - Tank Calibration - Calibration of Barge Tanks
API MPMS CH.2.8A 1991
Calibration of Tanks on Ships and Oceangoing Barges
API MPMS CH.2.8B 1995
Establishment of the Location of the Reference Gauge Point and the Gauge Height of Tanks on Marine Tank Vessels
API MPMS CH.20.1 1993
Allocation Measurement
API MPMS CH.20.3 2013
Measurement of Multi-phase Flow
API MPMS CH.21.1 1993
Electronic Gas Measurement
API MPMS CH.21.2 1998
Electronic Liquid Volume Measurement Using Positive Displacement and Turbine Meters
API MPMS CH.21.2-A1 2000
Addendum 1 to flow Measurement Using Electronic Metering Systems, Inferred Mass
API MPMS CH.22.1 2006
Testing Protocols—General Guidelines for Developing Testing Protocols for Devices Used in the Measurement of Hydrocarbon Fluids
API MPMS CH.22.2 2005
Testing Protocols—Differential Pressure Flow Measurement Devices
API MPMS CH.3.1A 2005
Manual Gauging of Petroleum and Petroleum products
API MPMS CH.3.1B 2001
Standard Practice for Level Measurement of Liquid Hydrocarbons in Stationary Tanks by Automatic Tank Gauging
API MPMS CH.3.2 1995
Tank Gauging - Gauging Petroleum and Petroleum Products in Tank Cars
API MPMS CH.3.3 1996
Level Measurement of Liquid Hydrocarbons in Stationary Pressurized Storage Tanks by Automatic Tank Gauging
API MPMS CH.3.4 1995
Standard Practice for Level Measurement of Liquid Hydrocarbons on Marine Vessels by Automatic Tank Gauging
API MPMS CH.3.5 1997
Standard Practice for Level Measurement of Liquid Light Hydrocarbons on Marine Vessels by Automatic Tank Gauging
API MPMS CH.3.6 2001
Measurement of Liquid Hydrocarbons by Hybrid Tank Measurement Systems
API MPMS CH.4.1 2005
Proving Systems - Introduction
API MPMS CH.4.2 2003
Displacement provers
API MPMS CH.4.4 1998
Tank Provers
API MPMS CH.4.5 2000
Master - Meter Provers
API MPMS CH.4.6 1999
Pulse Interpolation
API MPMS CH.4.7 2009
Field - Standard Test Measures
API MPMS CH.4.8 1995
Operation of Proving Systems
API MPMS CH.4.9.1 2005
Methods of Calibration for Displacement and Volumetric Tank Provers Part 1Introduction to the Determination of the Volume of Displacement and Tank Provers
API MPMS CH.4.9.2 2005
Methods of Calibration for Displacement and Volumetric Tank Provers Part 2 Determination of the Volume of Displacement and Tank Provers by the Water draw Method of Calibration
API MPMS CH.4.9.3 2006
Methods of Calibration for Displacement and Volumetric Tank Provers Part 3 Determination of the Volume of Displacement and Tank Provers by the Master Meter Method of Calibration
API MPMS CH.4.9.4 2007
Methods of Calibration for Displacement and Volumetric Tank Provers Part 4 Determination of the Volume of Displacement and Tank Provers by the Gravimetric Method of Calibration
API MPMS CH.5.1 2005
General Considerations for Measurement by Meters
API MPMS CH.5.2 2005
Measurement of Liquid Hydrocarbons by Displacement Meters
API MPMS CH.5.3 2005
Measurement of Liquid Hydrocarbons by Turbine Meters
API MPMS CH.5.4 2005
Accessory Equipment for Liquid Meters
API MPMS CH.5.5 2005
Fidelity and Security of Flow Measurement Pulsed-data transmission Systems
API MPMS CH.5.6 2002
Measurement of Liquid Hydrocarbons by Coriolis Meters
API MPMS CH.5.8 2005
Measurement of Liquid Hydrocarbons by Ultrasonic Flowmeters Using Transit Time Technology
API MPMS CH.6.1 1991
Lease Automatic Custody Transfer (LACT) Systems
API MPMS CH.6.2 2004
Loading Rack Metering Systems
API MPMS CH.6.4 2007
Metering Systems for Aviation Fuelling Facilities
API MPMS CH.6.5 1991
Metering Systems for Loading and Unloading Marine Bulk Carriers
API MPMS CH.6.6 1991
Pipeline Metering Systems
API MPMS CH.6.7 1991
Metering Viscous Hydrocarbons
API MPMS CH.7 2001
Temperature Determination
API MPMS CH.8.1 1995
Manual Sampling of Petroleum and Petroleum Products
API MPMS CH.8.2 1995
Automatic Sampling of Petroleum and Petroleum Products
API MPMS CH.8.3 1995
Standard Practice for Mixing and Handling of Liquid Samples of Petroleum and Petroleum Products
API MPMS CH.8.4 2004
Standard Practice for Sampling and Handling of Fuels for Volatility Measurement
API MPMS CH.9.1 2002
Standard Test Method for Density, Relative density (Specific Gravity) or API Gravity of Crude Petroleum and Liquid Petroleum Products by Hydrometer Method
API MPMS CH.9.2 2003
Standard Test Method for Density or Relative density of Light Hydrocarbons by Pressure Hydrometer
API MPMS CH.9.3 2002
Standard Test Method for Density, Relative Density, and API Gravity of Crude Petroleum and Liquid Petroleum Products by Thermo-hydrometer Method
API PUBL. 2218 1999
Fireproofing Practices in Petroleum and Petrochemical Processing Plants
API PUBL. 2510A 1996
Fire-protection Considerations for the Design and Operation of Liquefied Petroleum Gas (LPG) Storage Facilities
API RP 14B 2005
Orientation Programs for Personnel Going Offshore for First Time
API RP 14C 2001
Qualification Programs for Offshore Production Personnel Who Work with Safety Devices
API RP 14E 1991
Training of Personnel in Non-operating Emergencies
API RP 14FZ 2008
Recommended Practice for Training and Qualification of Personnel in Well Control Equipment and Techniques for Wireline Operations on Offshore Locations
API RP 14G 2007
Training of Personnel in Rescue of Persons from Water
API RP 14H 2007
Planning, Designing and Constructing Tension Leg Platforms
API RP 14J 2001
Design, Installation, Repair and Operation of Subsurface Safety Valve Systems
API RP 17A
Recommended Practices for Design and Operation of Subsea Production Systems
API RP 17B 2006
Design and Installation of Offshore Production Platform Piping Systems
API RP 17E
ROV Interfaces with Subsea Production Control Umbilicals
API RP 17H
Remotely Operated Vehicle (ROV) Interfaces with Subsea Equipment
API RP 17N
Recommended Practice for Reliability, Technical Risk and Integrity Management
API RP 2021 2001
Design and Installation of Electrical Systems for Fixed and Floating Offshore Petroleum Facilities for Unclassified and Class I, Zone 0, Zone 1, and Zone 2 Locations
API RP 2028 2002
Recommended Practice for Fire Prevention and Control on Open Type Offshore Production Platforms
API RP 2030 2005
Recommended Practice for Installation, Maintenance and Repair of Surface Safety Valves and Underwater Safety Valves Offshore
API RP 2214 2004
Recommended Practice for Design and Hazards Analysis for Offshore Production Facilities
API RP 2216 2003
Design and Operation of Subsea Production Systems - General Requirements and Recommendations
API RP 2350 2005
Recommended Practice for Flexible Pipe
API RP 2T 1997
Blowout Prevention Equipment Systems for Drilling Operations
API RP 500 1997
Recommended Practice for Well Control Operations
API RP 520 P2 2008
Diverter Systems Equipment and Operations
API RP 520 Pl 2008
Use of Subsea Wet-gas Flowmeters in Allocation Measurement Systems
API RP 53 1997
Recommended Practice for Measurement of Multiphase Flow
API RP 540 1999
Recommended Practice for Field Analysis of Crude Oil Samples Containing from Two to Fifty Percent Water by Volume
API RP 551 1993
Recommended Practice for Classification of Locations for Electrical Installations at Petroleum Facilities Classified as Class 1 Division 1 and 2
API RP 552 1994
Sizing, Selection and Installation of Pressure Relieving Devices in Refineries: Part l Sizing and Selection
API RP 553 1998
Sizing, Selection and Installation of Pressure Relieving Devices in Refineries: Part ll Installation
API RP 554 2007
Electrical Installations in Petroleum Processing Plants
API RP 555 2001
Process measurement Instrumentation
API RP 572 2009
Transmission Systems
API RP 573 2002
Refinery Control Valves
API RP 574 2009
Process Control Systems Part l - process Control Systems Functions and Functional Specification Development
API RP 576 2009
Process Analyzers
API RP 59 2006
Inspection Practices for Pressure Vessels
API RP 591 2008
Inspection of Fired Boilers and Heaters
API RP 64 2001
Inspection Practices for Piping System Components
API RP T-1 1995
Inspection of Pressure Relieving Devices
API RP T-2 2001
Process Valve Qualification Procedure
API RP T-4 1995
Management of Atmospheric Storage Tank Fires
API RP T-6 2002
Flame Arrests in Piping Systems
API RP T-7 1995
Application of Fixed Water Spray Systems for Fire Protection in the Petroleum and Petrochemical Industries
API RP85 2003
Spark Ignition Properties of Hand Tools
API RP86 2005
Ignition Risk of Hydrocarbon Vapours By Hot Surfaces in the Open Air
API RP87 2007
Overfill Protection for Storage Tanks in Petroleum Facilities
API SPEC 14A 2005
Petroleum and Natural Gas Industries - Pipeline Transportation Systems - Pipeline Valves
API SPEC 6D 2008
Fire Test for Valves
API SPEC 6FA 1999
Specification for Fire Test for Valves with Automatic Backseats
API SPEC 6FC 2009
Specification for Subsurface Safety Valve Equipment
API STD 2003 2008
Guide for Pressure-Relieving and De-pressurising Systems - Petroleum, Petrochemical and Natural Gas Industries
API STD 2015 2001
Flanged Steel Pressure Relief Valves
API STD 2551 1966
Seat Tightness of Pressure Relief Valves
API STD 2552 1966
Check Valves: Flanged, Lug, Water and Butt-Welding
API STD 2555 1966
Valve Inspection and Testing
API STD 2560 2003
Metal Plug Valves - Flanged, Threaded and Welding Ends
API STD 521 2007
Steel Gate, Globe and Check Valves for Sizes DN 100 and Smaller for the Petroleum and Natural Gas Industries
API STD 526 2009
Testing of Valves - Fire Type - Testing Requirements
API STD 527 1991
Metal Ball Valves - Flanges, Threaded and Butt Welding Ends
API STD 594 2004
Butterfly Valves: Double Flanged, Lug and Water-Type
API STD 598 2009
Machinery Protection Systems
API STD 599 2007
Protection Against Ignitions Arising Out of Static, Lightning and Stray Currents
API STD 602 2009
Requirements for Safe Entry and Cleaning of Petroleum Storage Tanks
API STD 607 2005
Standard Method for Measurement and Calibration of Horizontal tanks
API STD 608 2008
Measurement and Calibration of Spheres and Spheroids
API STD 609 2009
Liquid Calibration of Tanks
API STD 670 2003
Reconciliation of Liquid Pipeline Quantities
API TR 6F2 1999
Vortex Shedding Flowmeter for Measurement of Hydrocarbon Fluids
API TR 6Fl 1999
Performance of Ape and Anis End Connections in Fire Tests According to API Specification 6FA
Draft Standard 2007
Fire Resistance Improvements for API Flanges
AGA Standards using for Fiscal Metering measurement
AGA Report No. 3 Part 1 (2012)
Orifice Metering of Natural Gas: General Equations & Uncertainty Guidelines
AGA Report No. 3 Part 2 (2000)
Orifice Metering of Natural Gas: Specification and Installation Requirements
AGA Report No. 3 Part 3 (1992)
Orifice Metering of Natural Gas and Other Related Hydrocarbon Fluids - Concentric, Square-edged Orifice Meters; Natural Gas Applications
AGA Report No. 3 Part 4 (1992)
Orifice Metering of Natural Gas: Background, Development Implementation Procedure
AGA Report No. 4 A (2009)
Natural Gas Contract Measurement and Quality
AGA Report No. 5 (2009)
Natural Gas Energy Measurement
AGA Report No. 6 (2013)
Field Proving of Gas Meters Using Transfer Methods
AGA Report No. 7 (2006)
Measurement of natural Gas by Turbine Meter
AGA Report No. 8 (1994)
Compressibility Factor of Natural Gas and Related Hydrocarbon Gases
AGA Report No. 9 (2007)
Measurement of Gas by Multipath Ultrasonic Meters
AGA Report No. 10 (2003)
Speed of Sound in Natural Gas and Other Related Hydrocarbon Gases
AGA Report No. 11 (2013)
