Cold cathode gauges are costlier comparatively.
Hot cathode gauges gets oxidised if oxygen is present. Also analyte gas may dissociate at high temperature.
Alphatron ionization gauge provides cheap alternative in decomposable environment.
Here an alpha particle emmiter is used to ionise the gas.The emmiter is positively-biased to collect negative ions which are generated by the impact of positively charged alpha-particle.
The current generated is proportional to degree of vacuum inside gauge. A voltmeter measures voltage across resistor. It is also used as smoke detectors.
Good Info. Keep going.
Good, brief, accurate & cool.
