As with the line-to-line voltage test, if zero volts are measured on both the line and load sides of the fuse, the fuse is not necessarily open.
The feeder or branch-circuit supplying the motor circuit may be in a single-phase condition, or a fuse in a second disconnect ( upstream from where you are taking voltage measurements) may be open.
A) False
B) True
Show Answer
Answer:B
