ASME Valve Standard & ASME Standard Name
ASME A105/105M
Standard Specification for Carbon Steel Forgings for piping applications
ASME A181/181M
Standard Specification for Carbon Steel Forgings for General purpose piping
ASME A182/182M
Standard Specification for forged or rolled alloy-steel pipe flanges, forged fittings and valves and parts for high-temperature service
ASME A727/727M
Standard specification for carbon steel forgings for piping components with inherent notch toughness.
ASME A961
Standard Specification for Common Requirements for Steel Flanges, Forged Fittings, valves, and Parts for Piping Applications
ASME B462
Standard Specification for Forged or Rolled UNS N08020, UNS N08024, UNS N08026, UNS N08367, and UNS R20033 Alloy Pipe Flanges, Forged Fittings, and Valves and Parts for Corrosive High-Temperature Service
ASME B834
Standard Specification for Pressure Consolidated Powder Metallurgy Iron-Nickel- Chromium-Molybdenum (UNS N08367) and Nickel- Chromium Molybdenum Columbium (Nb) (UNS N06625) Alloy Pipe Flanges, Fittings, Valves, and Parts
ASME D5500
Standard Test Method for Vehicle Evaluation of Unleaded Automotive Spark-ignition Engine Fuel for Intake Valve Deposit Formation
ASME F885
Standard Specification for Envelope Dimensions for Bronze Globe Valves NPS 1/4 to 2 El-1996 R(1996)
ASME F992
Standard Specification for Valve Label Plates El-1997 R(1997)
ASME F993
Standard Specification for Valve Locking Devices El-1997 R(1997)
ASME F1020
Standard Specification for Line-Blind Valves for marine Applications El-1996 RI’1996)
ASME F1098
Standard Specification for Envelope Dimensions for Butterfly Valves - NPS 2 to 24 EI-1993 R(1993)
ASME F1271
Standard Specification for Spill Valves for Use in Marine Tank Liquid Overpressure Protections Applications EI-1995 R (1995)
ASME F1370
Standard Specification for Pressure Reducing valves for Water Systems, Shipboard
ASME F1508
Standard Specification for Angle Style, Pressure Relief Valves for Steam, Gas, and Liquid Services
ASME F1565
Standard Specification for Pressure-Reducing Valves for Steam Service
ASME F1792
Standard Specification for Special Requirements for Valves Used in Gaseous Oxygen Service
ASME F1793
Standard Specification for Automatic Shut-Off Valves (Also Known as Excess Flow Valves, EFV) for Air or Nitrogen Service
ASME F1794
Standard Specification for Hand operated, Globe-Style Valves for Gas (Except Oxygen Gas), and Hydraulic Systems
ASME F1795
standard Specification for Pressure-Reducing Valves for Air or Nitrogen Systems
ASME A230
Standard specification for steel wire oil - tempered carbon valve spring quality
ASME A232
Standard specification for chromium - vanadium alloy steel valve spring quality
ASME A350
Standard specification for forged or rolled carbon and alloy steel flanges forged fittings and valves and parts for low - temperature service
ASME A338
Standard specification for ultrasonic examination of heavy steel forgings
ASME A694
Standard specification for forgings carbon and alloy steel for pipe flanges fittings valves and parts for high - pressure transmission service
ASME A404
Standards specification for forged or rolled alloy - steel pipe flanges forged fittings and valves and parts specially heat treated for high temperature service
ASME A522
Forged or rolled 8% and 9% nickel alloy steel flanges fittings valves and parts for low - temperature service
