Radiometric Level Measurement
Radiometric instrumentation is used where other measuring principles can not be used anymore due to extreme process conditions or because of mechanical, geometric or construction conditions. Besides continuous level measurement, the radiometric measurement can be used for for point level detection, interface and density measurement.This article gives an overview of how the common level measurement devices work, covering; radar level transmitters, guided radar transmitters, ultrasonic level transmitters and finally capacitance level transmitters.
Interface measurement
A gamma radiation source and a Gamma sensor/transmitter are mounted on opposite sides of the vessel in a height such that both liquids are irradiated. The radiation source may also be mounted inside the vessel.
The Gamma transmitter calculates the position of the interface layer from the intensity of the received radiation. Its value is between 0% (lowest possible position) and 100% (highest possible position).
Advantages at a glance
• Four measuring tasks in one measuring principle
• Non-contact, external measurement for the highest degree of safety and
reliability under the most extreme process conditions
• Measure interface level between liquid, foam (mixture between oil and water) and gas can be used in oil/water separator.
Radar level transmitters
How do radar level transmitters work?
Radar level transmitters work with high-frequency radar pulses which are emitted by an antenna and reflected from the product surface. The time of flight of the reflected radar pulse is directly proportionate to the distance traveled. If the tank geometry is known, the level can be calculated from this variable.
Advantages of radar level transmitters
- Very accurate – ±0.5 mm (0.02 inches)
- Installation at top
- Non-contact
- Accuracy independent of dielectric constant, density and conductivity
- No re-setup required when changing liquids
Things to take into account:
- Must take into account tank design
- Foam can be an issue
- Blocking distance
- Turbulent surfaces
- Minimum dielectric constant
Guided Radar level transmitters
How do Guided Radar level transmitters work?
Guided Radar level transmitters work with high-frequency radar pulses which are guided along a probe. As the pluses impact the medium surface, the characteristic impedance changes and part of the emitted pulse is reflected. The time between pulse launching and receiving is measured and analysed by the instrument and constitutes a direct measure for the distance between the process connection and the product surface.
Advantages of Guided Radar level transmitters
Very accurate – ±0.2 mm (0.04 inches)
Works with some foam
Installation at top
Heavy foam can be an issue
Blocking Distance
Turbulent surfaces
Ultrasonic level transmitters
How do Ultrasonic level transmitters work?
Ultrasonic measurement is based on the time-of-flight principle. A sensor emits ultrasonic pulses which the surface of the medium reflects and the sensor detects again. The required time of flight is a measure for the distance travelled in the empty part of the tank. This value is deducted from the overall height of the tank to yield the level.
Advantages of Ultrasonic level transmitters
Non-contact (lowest cost)
Installation at top
Accuracy independent of density changes, dielectric or conductivity
No calibration with medium required
Minimum density required
Foam is an issue
Blocking Distance
Turbulent surfaces
Vapours/gas above the liquid
Temperature difference between liquid and sensor
No vacuum (10 psia), no high pressures (44 psia)
Capacitance level transmitters
How do Capacitance level transmitters work?
The principle of capacitive level measurement is based on the change in capacitance of the capacitor due to the change in the level formed by the probe and the container wall. When the probe is in the air, a low capacitance is measured. When the container is filled, the capacitance of the capacitor increases the more the probe is covered. A capacitance probe may be compared to an electric condenser. As the tank is filled, the probe capacity increases. This change is electrically analysed.
Advantages of Capacitance level transmitters
Very cost effective
Established principle
Fast speed of response
Interface measurement possible
High temperatures and pressures possible
Many versions
Conductive/insulator
Probe coating – chemical compatibility
Ground reference tube
Non-metallic
Re-calibration with different media
10 pF minimum span
Author - Mircea Tomescu
