Both potentiometers and rheostats can be classified as linear or taper.
When classified as __________, the percentage of output voltage varies directly with the percentage of tap.
When classified as __________, the percentage of output voltage does not vary directly with the percentage of tap.
A) linear; taper
B) linear; linear
C) taper; linear
D) taper; taper
Show Answer
Answer:A
