Both potentiometers and rheostats can be classified as linear or taper ___
Both potentiometers and rheostats can be classified as linear or taper.
When classified as ___________, the percentage of output voltage varies directly with the percentage of tap.
When classified as ___________, the percentage of output voltage does not vary directly with the percentage of tap.
A) linear; linear
B) taper; linear
C) taper; taper
D) linear; taper
Show Answer
Answer:D
