Can liquid turbine flow meter to measure waste water?
i bought a 3" turbine flow meter from below China flow meter supplier:
can turbine flow meter to measure waste water? sewage ? there are some particles and solids inside .
Theoritically it will work, but make sure the solid particles do not obstruct or cause damage to the turbine blade.
It also depends on type of solid particles, particle size, ratio of solids etc.
You have to consult the flow meter vendor so that they can suggest you precisely.
Actually I can’t guarantee that it will work but the most suitable flow transmit will be the magnetic flow meter
thank you for your reply , this information is really helpful.
thank you , i will buy magnetic flow meter
