Can transformers be operated at voltages other than rated voltages?
In some cases, transformers can be operated at voltages below the nameplate rated voltage. In NO case should a transformer be operated in excess of its nameplate rating unless tap changer provided. When operating below the rated voltage the KVA capacity is reduced correspondingly.
