Choose which the following statements is a correct statement?
Which of the following statements is correct?
A. The magnetic flux inside the exciting coil is the same as on its outer surface
B. The magnetic flux inside an exciting coil is zero.
C. The magnetic flux inside the exciting coil is greater than that on its outside surface.
D. The magnetic flux inside the exciting coil is lower than that on the outside surface.
Show Answer
Answer: A
