Control Valve Accessories
1.Handwheel
  • It is used for manual operation of control valve during start up or event failure.
  • They are frequently used when lockup or bypass valves are not provided.
    HTB1RmGtKVXXXXXvXVXXq6xXFXXXU
2.Limit switches and solenoid
  • Limit switches are mounted on top to operate signal lights for valve position, valve operation or alarm.
  • Solenoid valve may be provided for remote loading and unloading of valve.
    total_valve_sol_diagram
3.Booster relay
4. Lockup Valve
5.Capacity tank
6. Transducers
  • Electronic control loops require I/P converter when control valve is pneumatically operated.
  • If control valve is subjected to vibrations they must be mounted on rigid support.
7. Jacketed bodies
  • They are required when valve body needs to be heated.
  • They provide efficient and uniform heating using copper tubing tracing.
8.Airsets
  • Most common accessory is air filter regulator.
  • Filter removes air-particulates.
    spr11_b2b_schematic
9.Ratio & reversing relays:
  • A ratio relay is used to multiply or divide inlet pressure
  • Reversing realy is used when control action needs to be reversed
    E.g. Split range valve may be operated where one is air to open and other is air to close.
  • A reversing relay might be used with one of the valves to achieve desired action.
Nice Article.
