D'Arsonval Movement
A meter movement based upon the permanent-magnet DC motor principle: a small coil of wire supported on jewel bearings or taut band between the poles of a permanent magnet. The magnetic field of the DC current passing through the coil interacts with the magnet’s field, causing rotation of the coil and an attached pointer against the restoring force of coil springs.
