Unisol 24 port Mini Din rail patch panel is compact in size and can be mounted in a cabinet with other din rail equipment. where Din Rail mount enclosures keep the pitching in close proximity to the active equipment it serves and minimizes cable management in the cabinet.
Mini Din rail patch panel solve many of the problems installers and integrator have faced when trying to adapt a conventional fiber optic patch panel for use in power, control, SCADA and industrial cabinets. Din rail mount enclosure is used in manufacturing industries to connect plant floor assets to a central control network requires a robust network.
The compact size of the 24 port Mini Din rail patch panel saves space especially when it is mounted within enclosures or cabinet with other din rail mount equipment.
Din Rail mount enclosures keep the patching in close proximity to the active equipment it serves and minimizes cable connectivity in the cabinet.
Din rail mounted fiber patch panel have cable entry from both bottom and top of the enclosure which allows two cables to be secured using a PG 13.5 cable gland.
Din rail fiber optic patch panel is used in manufacturing industries to connect plant floor assets to a central control network requires a robust network. 24 port Mini Din rail patch panel can be loaded with a variety of adapters like ST, SC, FC and LC. It can support up to 12 ports when fully loaded with adapters.
