Different types of Din rail patch panel
Din rail patch panel provide effective patching solutions for industrial networks or applications, inside control panels and distribution cabinets where DIN mounted equipment used.
This Din Rail patch panel includes three different types of LIU’s.
Nano (6 port) Din Rail patch panel
Nano (6 port) Din rail patch panel used in industrial applications as it has a compact and ruggedly designed case.
  • Where there are space constraint and limited connectivity, Din Rail enclosure will support up to 6port with SC/ST/LC type of connector is required.
  • UNISOL Nano Din rail patch panel is designed to reinforce fusion splicing or direct termination of the fiber.
  • It includes a splice tray for fusion splicing and befitting for mounting on 35mm Din Rail Panels.
Micro (12 port) Din Rail patch panel
Unisol Micro (12 port) Din rail patch panel designed to support fusion Splicing or direct Termination of the fibers and also used for industrial applications.
  • Micro Din rail patch panel can reinforce up to 12 port terminations in SC/ST/LC type connectors.
  • These type of enclosures are also is suitable for CCTV and surveillance applications.
  • The device contains a splice tray for fusion splicing and suitable for mounting in 35mm Din Rail panels where there is space constraint inside PLC’s.
Miniature (24 port) Din Rail patch panel
Unisol Mini (24 port) Din rail patch panel used in industrial applications as it has a compact and ruggedly designed case.
  • Mini Din rail patch panel designed to support for fusion Splicing or direct termination of the fibers.
  • Mini Din rail patch panel can reinforce up to 24 ports in SC/LC type of connectors, where there is maximum no. of fiber links can be required with multiple fiber cable inputs.
  • These enclosures include a splice tray for fusion splicing and suitable for mounting in 35mm Din rail Panels.
Awesome write up, however pictorial illustrations of each type of Din Rail Patch Panel would have cemented the topic
