Din Rail LIU is designed to support fusion splicing or direct termination of the fibers. Because of its compact and ruggedly designed case, it is suitable for industrial applications. Din rail mounted patch panel includes a splice tray for fusion splicing.
Din rail enclosure is compact in size and can be mounted on the cabinet with other din rail equipment where there is space constraint inside PLC’s.
Din Rail mount enclosures are suitable to mount in substation automation networks and these can be used to provide a maximum number of fiber connections in a minimal footprint.
Din rail mount fiber patch panel is used in CCTV traffic monitoring, toll systems and environmental monitoring equipment where these can be secured in small wayside cabinet backplane or side panel. The patch panel can be loaded with a variety of adapters like ST, SC, FC and LC.
