Direct Operated Downstream Pressure Regulating Valves Working Principle
Downstream Pressure regulating valves are self contained, Self Operated control devices, which use energy from the controlled system to operate and regulate pressures. Valve Solutions manufactures a variety of pressure reducing regulators to manage downstream system pressures in low, medium, high flow applications, model features a diaphragm type, piston type or combination of both to suit different applications
A pressure reducing regulator maintains a desired reduced outlet pressure while providing the required fluid flow to satisfy a variable downstream demand. The valve at which the reduced pressure is maintained is the outlet pressure setting of the regulator.
In operation, a direct operated, pressure reducing regulator senses the downstream pressure through either internal pressure registration or an external control line. This downstream pressure opposes a spring which moves the diaphragm and valve plug to change the size of the flow path through the regulator.
Characteristically direct operator regulators are adequate for narrow-range control, and where the allowable change in output pressure can be 10 to 20% of the outlet pressure setting. This 10 to 20% is typical although finer control can be achieved depending on the specific application requirement.
Direct%20Operated%20Downstream%20Pressure%20Regulating%20Valves%20Working%20Principle
Reference : Valve Solutions
