Disadvantages of globe valve
- There is generally High head loss in globe valves.
- In globe valves generally considerable power is required to operate.
- Globe valve is used noisy in high pressure applications.
- In globe valve large openings is necessary for disk assembly.
- Globe valves have heavier weight than other valves of the same flow rating.
- In globe valves there is cantilevered mounting of the disk to the stem.
