Distinguish between Open Loop and Closed Loop System?
The control system in which the output quantity has no effect upon the input quantity are called open loop control system. This means that the output is not feedback to the input for correction.
The control system in which the output has an effect upon the input quantity so as to maintain the desired output values are called closed loop control system.
Distinguish%20between%20open%20loop%20and%20closed%20loop%20system
