A term used to describe a type of valve flow characteristic where for equal increments of valve plug travel the change in flow rate with respect to travel may be expressed as a constant percent of the flow rate at the time of the change.
The change in flow rate observed with respect to travel will be relatively small when the valve plug is near its seat and relatively high when the valve plug is nearly wide open.
