Rack mount fiber patch panel provides cross-connect and interconnects capabilities for splicing & terminating optic fiber cables, pigtails in the fiber access network. Rackmount fiber optic patch panel and splice enclosures in data cabinets are available pre-loaded with any connector interface required. These 19” 1U rack mount fiber patch panels are ideal for high-density LAN interconnect or cross-connect patching.
These Rackmount fiber patch panels are compatible with standard 19” and 23” equipment racks and are designed to accept wire works, adapter strips, and splice trays or distribution modules. Our rack mount panels are fabricated from 16-gauge mild steel with corrosion-resistant seven tank process powder coating to provide excellent protection for the inside fibers.
The Rackmount fiber patch panel ears can also be adjusted to 3 different lengths from front to rear for even more flexibility. Each side has large grommet openings for safe horizontal cable routing. Each enclosure is supplied with an accessory pack that includes mounting ears, cable glands, cable ties for cable management, and a cable ID label for the installed cables.
