If the transmitter signal is used for controlling, then put the controller on manual.
Connect a digital multimeter in the current range in series with the transmitter output.
Isolate the process valve
Isolate the instrument isolation valve.
Open the equalising valve
Open the bleed valve and de-pressurise the transmitter.
Check for 4.00mA output signal, if not, adjust the zero screw.
