Fieldbus has many advantages over conventional point-to-point wiring:
A significant reduction in installation costs (typically 20% to 40% savings). This saving comes from reduced wiring, connections, junction boxes, marshalling cabinets, cable trays and supports etc.
Perhaps more importantly the number of connectors and connections is drastically reduced (typically 80% reduction). This is important because most problems occur because of connector failure (i.e. open circuits, shorts, water ingress or corrosion)
System expansion and modification is simpler and less expensive since only the additional cable run from the existing network to the new device must be installed.
Two-way communication means that additional information such as calibration and configuration data, diagnostic and test information, device documentation such as device tag numbers; serial numbers service history etc. can be communicated over the network. Equipment maintenance and servicing become more centralized.
Since communication is digital, accuracy is not affected by noise, interference or electrical loading effects etc. This is a particular advantage in transmitting analogue values.
Open standards mean that multi-vendor systems can be constructed. Product certification ensures that communication will work between devices from different manufacturers.
