ACRONYMS | FULL MEANING |
Ack | Acknowledge |
AE | Application Entity |
AI | Analog Input |
AO | Analog Output |
AP | Application Program |
AP | Application Process |
APDU | Application Layer Protocol Data Unit |
AR | Application Relationship |
AREP | Application Relationship End Point |
ARP | Ethernet Address Resolution Protocol |
ARPM | Application Relationship Protocol Machine |
ASN.1 | Abstract Syntax Notation 1 |
BOOTP | Bootstrap Protocol |
CAP | Control Application Process |
Cas | Cascade |
CD | Compel Data |
CFF | Capability File Format |
CFF | Common File Format |
CNF | Confirmation |
CNLS | Connectionless |
COM | Communication |
Config | Configuration |
CONN | Connection-Oriented |
CSMA/CD | Carrier Sense Multiple Access / Collision Detect |
DAP | Device Application Process |
DCS | Distributed Control System |
DD | Device Description |
DDL | Device Description Language |
DevId | Device Identifier |
DHCP | Dynamic Host Configuratin Protocol |
DI | Discrete Input |
DL | Data Link |
DLCEP | Data Link Connection End Point |
DLL | Data Link Layer |
Dlme | Data Link Layer Management Entitity |
DLPDU | Data Link Protocol Data Unit |
DLSAP | Data Link Service Access Point |
DMA | Direct Memory Access |
DNS | Do Not Select |
DO | Discrete Output |
DPS | Draft Preliminary Specification |
DS | Data Structure |
DTC | Data Transfer Confirmed |
DTU | Data Transfer Unconfirmed |
DUT | Device Under Test |
DV | Dynamic List of Variable List |
EFD | (High Speed) Ethernet Field Device |
EGP | Exterior Gateway Protocol |
EP | Ethernet Presence |
EPI | Ethernet Presence Interface |
ERR | Error |
EU | Engineering Unit |
FAS | Fieldbus Access Sublayer |
FB | Function Block |
FBAP | Function Block Application Process |
FDA | Field Device Access |
FDA | Field Device Application (Agent) |
FDA | Field Device Access Agent |
FDL | Fieldbus Data Link Layer |
FF | Fieldbus Foundation |
FFB | Flexible Function Block |
FMS | Fieldbus Message Specification |
FMS | Fieldbus Messaging System |
FS | Final Specification |
FSA | Fail-Safe Active |
FSA | Fault Statefail -Safe Active |
FSPM | FDA Service Protocol Machine |
Gen | Generic |
H1 | Hunk 1 |
HFD | HSE Field Device |
HL | Link Designator of a four-octet LONG DL-address |
HL.N.S | Four-octet LONG DL-address |
HLD | Higher Level Device |
HMA | HSE Management Agent |
HSE | High Speed Ehternet |
I/O | Input / Output |
IA | Initialization Acknowledge |
IANA | Internet Assigned Numbers Authority |
ICMP | Internet Control Message Protocol |
ICS | Implementation Conformance Statement |
ID | Identifier |
Id | Identifier |
IEEE | Institute of Electrical and Electronics Engineers |
IETF | Internet Engineering Task Force |
IGMP | Internet Group Management Protocol |
IMan | Initialization Manual |
IND | Indication |
INFO | Informational |
IP | Internet Protocol |
IPv4 | Internet Protocol, Version 4 |
IPv6 | Internet Protocol, Version 6 |
IR | Initialization Request |
IT | Information Technology |
IUT | Implementation Under Test |
LAN | Local Area Network |
LAS | Link Active Scheduler |
LD | Linking Device |
LDM | Last Delivered Message |
LLC | Logical Link Control |
LME | Layer Management Entity |
LO | Local Override |
LOP | Local Operator Panel |
LRE | LAN Redundancy Entity |
LS | Link Schedule |
LSB | Least Significant Bit |
LUV | Last Usable Value |
MAC | Medium Access Layer |
MAC | Medium/Media Access Control |
MAI | Multiple Analog Input |
MAO | Multiple Analog Output |
MAU | Medium Attachment Unit |
Max. | Maximum |
Mb/s | Megabits per second |
MDI | Multiple Digital Input |
MDI | Multiple Discrete Input |
MDO | Multiple Digital Output |
MDO | Multiple Discrete Output |
MDS | Medium Dependent Sublayer |
Mfr. | Manufacturer |
MIB | Management Information Base |
MIB-II | Management Information Base II |
MSB | Most Significant Bit |
Msg | Message |
MVC | Multi-Variable Container object |
N.S. | Sub-link Selector of a four-octet LONG DL-address |
NI | Not Invited |
NM | Network Management |
NMA | Network Management Agent |
NMIB | Network Management Information Base |
NST | Network Status Table |
NTP | Network Time Protocol |
OD | Object Description |
OD | Object Dictionary |
OSI | Open System Interconnection |
PD | Physical Device |
PD Tag | Physical Device Tag |
PDU | Protocol Data Unit |
PhPDU | Physical Layer Protocol Data Unit |
PHY | Physical Layer |
PICS | Protocol Implementation Conformance Statement |
PID | Proportional Integral Derivative (control algorithm) |
PLC | Programmable Logic Controller |
PN | Probe Node PDU |
PR | Probe Response PDU |
PROP | Proposed |
PS | Preliminary Specification |
PT | Pass Token |
RCas | Remote Cascade |
RED | Redundant |
Ref | Reference |
REQ | Request |
RFC | Request For Comments |
RFU | Reserved for Future Use |
ROut | Remote Output |
RSE | Remote Single Layer Embedded |
RSP | Response |
RT | Return Token |
SM | System Management |
SMI | Structure and Identification of Management Information |
SMIB | System Management Information Base |
SMK | System Management Kernel |
SMKP | System Management Kernel Protocol |
SMKPM | System Management Kernel Protocol Machine |
SMPM | Socket Mapping Protocol Machine |
SNMP | System Network Management Protocol |
SNTP | Simple Network Time Protocol |
STD | Standard |
SUT | System Under Test |
TCP | Transmission Control Protocol |
TCP/IP | Transmission Control Protocol / Internet Protocol |
TD | Time Distribution |
TOS | Type Of Service (IP definition) |
TTCN | Tree & Tabular Combined Notation |
TTL | Time To Live (IP definition) |
UDP | User Datagram Protocol |
VCR | Virtual Communication Relationship |
VCRL | Virtual Communication Relationship List |
VFD | Virtual Field Device |
FF Acronyms in Book | |
A | Arithmetic |
AA | Analog Alarm |
AHI | Analog Human Interface |
AI | Analog Input |
Auto | Automatic |
BG | Bias/Gain Station |
C | Calculate |
CAO | Complex Analog Output |
Cas | Cascade |
CDO | Complex Discrete Output |
CS | Control Selector |
DA | Digital Alarm |
DC | Device Control |
DHI | Digital Human Interface |
DL | Data Link |
DT | Deadtime |
FISCO | Fieldbus Instrinsically Safe Concept |
H1 | Fieldbus Low Speed Data Network |
HSE | High Speed Ethernet |
Iman | Initialization Manual |
IS | Input Selector |
IT | Integrator (Totalizer) |
LAS | Link Active Schedule |
LL | Lead Lag Controller |
LM | Link Master |
LS | Link Scheduling |
MAC | Management Access Control |
MAI | Multiple Analog Input Block |
Man | Manual |
MAO | Multiple Analog Output Block |
MDI | Multiple Discrete Input Block |
MDO | Multiple Discrete Output Block |
ML | Manual Loader |
OOS | Out Of Service |
OS | Output Splitter Block |
PD | Proportional Derivative |
PD | Process Data |
PI | Pulse Input |
PID | Proportional Integral Derivative |
RA | Ratio |
RB | Resource Block |
RX | Receive/Receiver |
SC | Signal Characterizer |
SOPID | Step Output PID |
SRG | Set Point Ramp Generator |
SS | Signal Splitter |
STP | Shielded Twisted Pair(s) |
T | Timer |
TD | Transducer Block |
TX | Transmit/ Transmitter |
UTP | Unshielded Twisted Pair(s) |
VCR | Virtual Communication Resource |
XD | Transducer |
non-FF Acronyms in Book | |
AWG | American Wire Gauge |
DCS | Digital Control System |
HMI | Human Machine Interface |
I/O | Input/Output |
IEC | International Electrotechnical Commission |
IS | Intrinsically Safe |
ISA | Instrumentation, Systems, & Automation Society |
ISO | International Standards Organization |
mA | milliamps |
NIS | Non-Intrinsically Safe |
OLE | Object Linking and Embedded |
OPC | OLE for Process Control |
PTB | Physikalisch Technische Bundesanstalt |
SCADA | Supervisory Control And Data Acquisition |
SP | Set Point |
VDC | Volts Direct Current |
XML | eXtensible Mark-up Languange |
