Final Year PLC Projects List
The following list provides the Programmable Logic Controllers final year projects.
- PLC Traffic Light System
- PLC Program to Implement Various Logic Gates
- PLC Program to Implement Various Boolean Functions
- PLC Program to Implement Various Boolean Functions With Don’t Care Condition
- PLC Program to Implement a Combinational Logic Circuit (1)
- PLC Program to Implement a Combinational Logic Circuit (2)
- PLC Program to Implement Binary to BCD Converter
- PLC Program to Implement BCD to Excess-3 Code Conversion
- PLC program to implement Excess-3 to BCD Conversion
- PLC Program to Implement Binary to Gray Code Conversion
- PLC Program to Implement Gray Code to Binary Conversion
- PLC Program to Implement BCD to Gray Code Conversion
- PLC Program to Implement 2-bit Magnitude Comparator
- PLC Program to Implement 4:1 Multiplexer
- PLC Program to Implement 8:1 Multiplexer
- PLC Program to Implement 1:8 Demultiplexer
- PLC Program to Implement 3 to 8 Line Decoder
- PLC Program to Implement 8 to 3 Encoder
- PLC Program to Implement SR Flip-Flop
- PLC Program to Operate Seven Segment Display
- PLC Program to Operate Stamping of Parts
- PLC Program to Implement D Flip Flop
- PLC Program to Implement T Flip Flop
- PLC Program to Simply Latch and Unlatch an Output
- PLC Program to Latch and Unlatch an Output by Sealing
- PLC Program to Latch and Unlatch Output With Time Delay
- PLC - Car Parking System
- PLC - Classroom Capacity
- PLC - Automatic Car-Wash
- PLC - Operate 4 Outputs - Delay
- PLC - Interlocking Drive Motors
- PLC - Forward/Reverse Drive
- PLC - Single Tank Level Control
- PLC - Two Tanks Level Control
- PLC - Series Tanks Level
- PLC - Parallel Tanks Level
- PLC - Tank - Heating Liquid
- PLC - Tank - Control Mixing
- PLC - Control Processing Line
- PLC - Bottle Filling System
- PLC - Conveyor - Count Parts
- PLC - Conveyor - Pack Parts
- PLC - Conveyor Sequence
- PLC - Drilling of Parts
- PLC - Cleaning/Rinsing Bottles
- PLC - Conveyor - Sort Parts
- PLC - Heat Tank - Steam Flow
- PLC - Products Heating/Mixing
- PLC - Maintain Tank Level
- PLC - Continuous Tank Reactor
- PLC - Heat/Bend Glass Tubes
- PLC - Bottle’s Capping Rotation
- PLC - Beverage Bottle Capping
- PLC - Conveyor Bottle Removal
- PLC - Event Time Measurement
- PLC - Light as Signal
- PLC - Reset NonRetentive O/P
- PLC - Counter Preset Value
- PLC - Drain Same Products
- PLC - Drain Different Products
- PLC - Display Tank Level
- PLC - Display More Tank Levels
- PLC - Spray-Painting
- PLC - Separate Big/Small Parts
- PLC - Operate Screwing of Parts
- PLC - Detect Burned Chips
- PLC - Store Process Data
- PLC - Store Temperature Data
- PLC - Oil/Water Separation
- 4 Lamp Process
- 4 Lamp Process Continous With Reverse Direction
- 4 Lamp Process Continous With 5 Count
- Mixing Process
- Mixing Process Continous
- Mixing Process With 5 count
- Bottel Filling Process
- Bottel Filling Process Continous
- Bottel Filling With Capping process
- Sensor Process
- Sensor Process Continous
PLC Tutorials and Projects
