dear all,
Anybody have GPS antenna installation drawing which needs to be installed on building.
(cable installation from GPS antenna to Receiver). Lightning arrestor should be installed between these two points. )
dear all,
Facilities with connections to the outside (GPS) may suffer damage due to lightning. Electronic components are extremely sensitive to high voltage from major energy sources such as lightning, which is the most common danger. It also has the characteristic of being completely unforeseeable.
To protect people and equipment from lightning, it is essential to ensure that all wired connections from building exteriors include the appropriate form of protection. It only takes one unprotected connection to admit the lightning, which then, causes damage by induction, to the other cables and equipment.
DOWNLOAD
GPS LIGHTNING PROTECTION WIRING DIAGRAM.pdf (236.4 KB)
GPS Lightning Protection.pdf (133.1 KB)
GPS Cable and Surge Protector Installation Guide.pdf (2.7 MB)
GPS Antenna Installation Guidelines.pdf (175.7 KB)
GPS antenna installations.pdf (1.3 MB)
Thanks Santhosh
