I install magnetic flowmeter and pressure transmitter with RTU, The problem occured measurement flowmeter is hunting , if pressure transmitter is not connected the reading is normal. Can anyone give me a solution?
check earthing of magnetic flow meter
Ok bro, I use grounding rod, How long minimum cable from magmeter to grounding rod?
