Hart communicator’s mostly used functions in calibration of a device
LSV= lower set value:
The minimum range value of device, it can measure
USV=upper set value:
The maximum value of device , it can measure
LRV=lower range value:
The minimum value to which device has to read it as 0%
USV=upper range value
The maximum value to which device has to read it as100%
Sensor zero trim:
To zero the sensor value (means which output is generating sensor to zero it)
D/A trim=digital to analog trim:
To zero the out put of transmitter,to generate the 0% out put at that state of the device
