How does a rotameter work?
Rotameters or variable area flowmeters operate on the principle that the variation in area of flow stream required to produce a constant pressure differential is proportional to the flow rate. The flowing fluid enters the bottom of the meter passes upward through a metering tube and around the float exiting at the top. The flow rate is read by noting the position of the float against the calibrated scale etched on the glass.
