How does the Precision Turbine Flowmeter generate a signal?
Electrical output is most often generated using the principle of reluctance. A pickup coil, wrapped around a permanent magnet, is installed on the exterior of the flow tube or the meter body immediately adjacent to the perimeter of the rotor. The magnet is the source of the magnetic flux field that cuts through the coil. Each blade of the Precision Turbine FlowMeter (PTF) rotor passing in close proximity to the pickup coil causes a deflection in the existing magnetic field. This change in the reluctance of the magnetic circuit generates a voltage pulse within the pickup coil.
Electrical output is also generated using the principle of inductance. A pickup coil is installed on the exterior of the flow tube immediately adjacent to the perimeter of the PTF rotor. The magnetic source of the flux field in this type of output is either the rotor itself or small magnets installed in the rotor. In the case of the rotor, the material of construction would be 17-4SS or some other magnetic material. The results are identical to that of the reluctance principal.
Many applications where flow is very low require a special type of coil assembly commonly referred to as Modulated Carrier. This type of coil produces no magnetic drag on the rotor, resulting in the ability to measure very small flows where velocity is minimal. Instead of a sine wave output, this coil assembly produces a carrier wave. Otherwise the performance of the meter is essentially the same as the reluctance coil design.
