Morning All
I am struggling to have access to the Analog output parameters on the Pr 5714D and I can not set the low and high parameters,I am using a transmitter (4-20 mA) as an input
Thanks in advance
Morning All
Thanks in advance
Yes that’s the one I am talking about
Thanks for your reply I will try now and let you know
You wanna display Analog high & low values by providing analog input or wanna generate Analog high & low values of the analog output.
I want both because I want to have a reading on the display and an signal from the analog output I can use to my Scada System ,For that people will need to go to the field to know the reading
Ok good so you can change O.LO, O.HI, DI.LO & DI.HI parameters.
Hi
Thanks for your reply but for more clarification .I put some parameters already on the DILO (4mA) ,; DIH ((20mA) and OLO,OHI some parameters
I still not having a good ready on the Display and it is a brand new one
Thanks in advance
Which values are displayed before & after implementing parameters.
On the display if i put as I said before
