If cavitation in valve is ever encountered, consider the following corrective actions:
The first is to equip the control valve with special trim and ensure that the plug and
seat are made of a hard facing material that can resist both the onset and effect of
cavitation (e.g. stellite hard facing).
The second is to use a valve with a low recovery coefficient.
The third is to increase the downstream pressure by installing a flow restrictor if
possible or reducing the pipe size of a short piece downstream.
If I go with option #3 - how do I distribute the pressure drop? I have 350 psig drop across the control valve. I am wanting to add an RO downstream. Do I let the RO see most of this pressure drop and only take about 50 psig across the valve?
