You should follow each manufacturer’s directions. For BW Honeywell Gas Detectors the manufacturer recommends the use of a soft damp cloth. The only approved cleaner is ACL Staticide. You should avoid exposing the sensor screens to moisture. DO NOT use computer keyboard air dusters to clean debris from sensor filters or products such as EconoClean, WD40, etc. as these will destroy the sensors.
