How-to select Pyrometer ?
Temperature Range:
Basic requirement to choose a pyrometer is to know the temperature range of the application. -
Spectral range:
The material of the measured object demands the correct selection of spectral range of pyrometer. -
Field of View (D: S ratio):
The larger the measuring distance/spot size (D:S) ratio the higher the optical resolution. The spot size has to be as big as the measured object to achieve a correct temperature measurement. -
Sighting:
For easy focusing of pyrometers to measure object, different sighting system are available i.e. aiming and View finder. -
Records of the data:
Data logging and companion software for data storage, retrieval and analysis. -
Calibration of Pyrometer:
A Pyrometer should be calibrated at desired temperature ranges.
