If any terminal reading from a CB does not give the rated voltage measurement, the CB should be ______________.
Sometimes turning off and resetting the CB seems to restore the correct voltage to the load terminals, but the CB should still be ______________.
Faulty contacts on the inside of the CB or a loose connection between the clip and the stab could cause the CB to ____________ ____________.
A) none of the answers
B) replaced; replaced; fail again
C) destroyed; replaced; fail again
D) destroyed; destroyed; fail again
Show Answer
Answer:B
