If interrupted at only one break point (single-break), the temperature could be high enough to melt the respective pad surfaces and cause ___ holes, where the metal at the entry/exit point melted
If interrupted at only one break point (single-break), the temperature could be high enough to melt the respective pad surfaces and cause _____________ ― holes, where the metal at the entry/exit point melted, splattered, and then solidified ― of the contact surface.
A) ductile
B) none of the answers
C) pitting
Show Answer
Answer:C
