If the switch is drawn in ____________ - ____________ configuration, the line and load wire terminals of the switch assembly are connected one each to stationary contact pads within the switch.
The movable bar or “_____________” within the switch is fitted with two contact pads, which, when assembled, align with the two stationary pads.
When the switch is opened, the circuit current is interrupted at two contact points, hence a ____________ - ____________ configuration.
A) double-break; double-break; actuator
B) double-break; double-break; double-break
C) actuator; double-break double-break
D) double-break; actuator; double-break
Show Answer
Answer:D
