In a comparison between a typical gate valve and a typical globe valve in the same water system application with both valves fully open, the gate valve has a ___ pressure drop and is normally used in ___ flow applications
In a comparison between a typical gate valve and a typical globe valve in the same water system application with both valves fully open, the gate valve has a __________ pressure drop and is normally used in __________ flow applications.
A. larger; throttling
B. larger; on/off
C. smaller; throttling
D. smaller; on/off
Show Answer
Answer: D
