In a comparison between globe valves and gate valves in the same water system application, globe valves ___
In a comparison between globe valves and gate valves in the same water system application, globe valves…
A. are less effective at throttling flow.
B. are less effective as pressure regulating valves.
C. produce a smaller pressure decrease when fully open.
D. require less force to open against large differential pressures.
Show Answer
Answer: D
