In most cases, a loss of voltage due to a ___ connection makes the load inoperative
In most cases, a loss of voltage due to a ____________ connection makes the load inoperative.
And, in most instances, if not corrected the heat buildup at the ____________ connection will cause the metals of the wire and terminal to melt or burn open, and shut down the supplied equipment.
A) loose; loose
B) none f the answers
C) tight; tight
D) tight; loose
Show Answer
Answer:A
