Which of the following involved the consideration in the selection of the type of electric drive for a particular application depends on
A. Speed control range and its nature
B. Starting torque
C. Environmental conditions
D. All of the above
E. None of the above
Show Answer
Answer: D
Which of the following is preferred for automatic drives?
A. Synchronous motors
B. Squirrel cage induction motor
C. Ward Leonard controlled dc motors
D. Any of the above
Show Answer
Answer: C
Which type of drive can be used for hoisting machinery
A. AC slip ring motor
B. Ward Leonard controlled DC shunt motor
C. DC compound motor
D. Any of the above
Show Answer
Answer: D
The motor normally used for crane travel is
C. Synchronous motor
D. DC differentially compound motor
Show Answer
Answer: A
When smooth and precise speed control over a wide range is desired, the motor preferred is
C. Wound rotor induction motor
D. Dc motor
Show Answer
Answer: D
When quick speed reversal is a consideration, the motor preferred is
D. Dc motor
Show Answer
Answer: D
