Instrumentation Abbreviations
DCS - Distributed Control System
PLC - Programmable Logic Controller
DCS/PLC: DCS (Distributed Control System) / PLC (Programmable Logic Controller) in a automated process/manufacturing plant is a window for plant operator to control, monitor the entire plant from a common place i.e. central control room. It also performs the safety interlocks of the plant.
ESD – Emergency Shutdown System. The ESD system forms part of the facility’s safety systems. Its prime function is to shutdown the facilities to a safe state in case of an emergency situation, thus protecting personnel, the environment and the asset.
PSS – Process Safety System : The PSS forms part of the facility’s safety systems. Upon command, it shall automatically carry out the safe shutdown of particular units or equipment as defined by the safety philosophies.
PCS – Process Control System : The PCS system forms part of facility’s control systems. It shall ensure a safe, reliable and efficient control and monitoring of the process plant and utilities.
FGS – Fire and Gas System – The F&G detection and protection system forms part of the facility’s safety systems. Its function is to mitigate against the effects of any fire and/or gas releases in order to protect personnel, the environment and the asset. The F&G system will continuously monitor the facilities and initiate the protective actions as defined in the safety philosophies.
HMI – Human Machine Interface : the HMI shall provide the facility for the operator to control and monitor the plant via mimic displays, alarms, trend displays and operstor commands.
EWS – Engineering Work Station: Engineering Work Station allows its control system’s (DCS,PLC, etc) maintenance, configuration and diagnostic.
ICSS – Integrated Control & Safety System
I/O – Input/Output
SOE – Sequence Of Events. SER – Sequence of Events Recorder : A facility provided by ICSS in order to identify and record the time of all events in any part of the system (controllers) of all subsystems.
IPF - Instrumented Protective Function : A function comprising the Initiator function, Logic Solver function and Final Element function for the purpose of preventing or mitigating Hazardous Situations.
IPS – Instrumented Protective System : The electromechanical, electronic and/or programmable electronic Logic Solver component of the Instrumented Protective Function, complete with input and output equipment.
MTBF – Mean Time Between Failures : MTBF ratings are measured in hours or years and indicate the reliability of equipment. Calculated by dividing the total unit operating hours accrued in a period by the number of unit failures that occurred during the same period.
Trip - An Instrumented Protective Function action to bring the Final Element(s) to a safe state.
RTU - Remote Terminal Units (RTUs), used to continually collect data from the sensors in the field, and process and send the information to a centralised Master Station.
SCADA - Supervisory Control and Data Acquisition (SCADA) is used to monitor and control remote plant and equipment.
Operator console - A group of equipment comprising VDU screens, keyboards, pointing devices and switches which are allocated to a defined part of the plant (e.g. “console for hydrogen units”).
TCP/IP - Transfer Control Protocol / Internet Protocol : The complete and (for internet use) necessary protocol that allows computers to communicate irrespective of brand, type, speed or operating system.
MMS – Machine Monitoring System
MCC – Motor Control Centre
SHARE IF ANY MISSED FROM THE ABOVE LIST
BPCS Basic Process Control System
DBB/SBB Double Block and Bleed/Single Block and Bleed
DP Differential Pressure
ETFE Ethylene/Tetrafluoroethylene Copolymer
FFT Fast Fourier transform
FMCW Frequency Modulated Continuous Wave
FPSO Floating, Production, Storage and Offloading
GWR Guided Wave Radar
ID Internal Diameter
LG Level Gauge
LNG Liquefied Natural Gas
LOP Layer Of Protection
LT Level Transmitter
LPG Liquefied Petroleum Gas
PPE Personal Protection Equipment
PTFE Polytetrafluoroethylene
PVDF Polyvinylidene Difluoride
MLI Magnetic Level Indicator
SIS Safety Instrumented System
SS Stainless Steel
